Bushman007
Feb 14, 2013Aspirant
ReadyNAS Duo and DLNA scan
Hi, I have a ReadyNAD DUO which is playing up again...never ending story! When I selected to run a scan on the folder/update the database it never ends. It has now been running for 3 days solid an...
Apr 08, 2013Guru - Experienced User
Cloud is correct, this is likely a file that ReadyDLNA is tripping over. Resetting the Duo to factory default is not likely to help, what you need to do is find the file that is causing the problem.
There is a debug mode for ReadyDLNA that would help you isolate the bad file.
