zakapatul
Mar 18, 2011Aspirant
Readynas Duo and the slow blinking blue light
Hello all, I'm the lucky owner of a readynas duo with a single Seagate disk of 1TB with default configuration (X-Raid i think). The Readynas was working fine for months until yesterday : i got this ...
zakapatul
mdgm wrote: Are both your disks showing solid green LEDs?
I'm pretty sure they are (i can not check being currently at work :/, will do asap).
mdgm wrote: Well I guess you could try powering the NAS off, then removing the power, waiting a minute or two, reconnecting the power then turning it on again.
Sadly i already tried... without success :( I think i will try the firmware re-install this weekend. I assume doing this i will lost all my configuration, my addons and so on... Not a big deal even if i spent a lot of time on it. Is there a risk for my data with this procedure ? If yes maybe would it be better to backup the disk content before ?
Thank you again for your support !
