zakapatul
Mar 18, 2011Aspirant
Readynas Duo and the slow blinking blue light
Hello all, I'm the lucky owner of a readynas duo with a single Seagate disk of 1TB with default configuration (X-Raid i think). The Readynas was working fine for months until yesterday : i got this ...
mdgm-ntgr
Mar 18, 2011NETGEAR Employee Retired
The firmware is stored on a separate 2GB partition to your data. It shouldn't be using anywhere close to that.
For example one of my NV+ units currently has only 530MB used:
If the firmware re-install is successful hopefully you'll get access to Frontview, SSH and/or CIFS and be able to backup your data. Otherwise you'd need to see if you can get tech support's help to get your system back up and running.
MDGM-NAS:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 530M 1.4G 27% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 4.1T 4.0T 68G 99% /c
