sdavis81
Feb 20, 2012Aspirant
ReadyNas Duo can't connect CIFS/TimeMachine after Lion
I use my ReadyNas for storing movies and for Time Machine. So my familiarity with all the nuances is not great. Everything was working fine how I set it up a few years ago until the Lion upgrade. I...
sdavis81
One other thing, I also run Fusion and upgraded from Fusion 2.0 to 4.1 because it had to be 64 bit. I used to not back up the Fusion files because it filled the disc. Now with 4.1 it said that Time Machine backups are OK and the "Auto-protect" feature will keep it clean. I did also set this up and that is how I figured out my backups weren't working.
Not sure if this has anything to do with it.
Thanks
Thanks
