sdavis81
Feb 20, 2012Aspirant
ReadyNas Duo can't connect CIFS/TimeMachine after Lion
I use my ReadyNas for storing movies and for Time Machine. So my familiarity with all the nuances is not great. Everything was working fine how I set it up a few years ago until the Lion upgrade. I...
mdgm-ntgr
Feb 20, 2012NETGEAR Employee Retired
As I suspected there's your problem. RAIDiator 4.1.6 (http://www.readynas.com/RAIDiator_4_1_6_Notes) was released back in July 2009. This was before Mac OS X 10.6 Snow Leopard was released.
For Mac OS X 10.6 Snow Leopard you should use 4.1.7 or later
For Mac OS X 10.7 Lion you need RAIDiator 4.1.8 or later
Open Frontview (click Setup in RAIDar) and go to System > Update > Remote. You should see the 4.1.8 firmware is available when you check for an update.
There are some performance issues with 4.1.8 so if you're not happy with the performance you can give 4.1.9 beta a try: http://www.readynas.com/forum/viewtopic.php?f=17&t=59222
