Formula400
Dec 29, 2011Aspirant
ReadyNas Duo, DLNA Streaming Music plays in wrong order
I wish to use my ReadyNas Duo NAS to stream music to my recently purchased Roberts 83i streaming radio. When I use the DLNA Server in the ReadyNas to stream to the Roberts, Album, Artists and TRACKS a...
Jan 03, 2012Guru - Experienced User
Not sure.
But one way to force the order is to re-tag your tracks so the title starts with the track number. (also start the file name itself with the track number). You need to use 01 for 1, otherwise you get 1, 10, 2, ....
This is somewhat tedious, but not quite as bad as it sounds, as there are some tag packages that let you do bulk renaming (and retagging). Anyway, then you get the right order no matter what player / server combination you use.
