docusn
Apr 19, 2009Aspirant
ReadyNAS Duo has wrong IP address
My LAN uses 192.168.0.x as it's IP range. The ReadyNAS is inaccessible and RAIDar shows the ReadyNAS ip as 192.168.1.50. Since I can not access the ReadyNAS how do I change the ip to get it back on...
alexmourinho
Nov 02, 2011Aspirant
I am trying to do the OS-reinstall, but to no avail. I have a DUO btw. I have the same problem the initial poster has. Wrong IP.
I am however not sure I am doing it right?
Since I am a complete idiot I prefer instructions like this:
1. Turn off your NAS.
2. Push the reset button.
3. Release the reset button.
4. Start the NAS.
I have done that 3 times. To no avail. Any ideas?
EDIT: I see I did it wrong.
The instruction (so I could understand it) should be:
2. Push the reset button. (Do not let go of it)
3. Start the NAS.
4. Wait until the LED lamps on the front blink the desired number of times (see table below).
5. Release the reset button.
Duo / NV / NV+ / X6/600
To perform an OS Re-install or Factory Default, this is managed via the Reset button on the back of the chassis.
Locate the reset pinhole.
ReadyNAS X6/600: the pinhole is on the back in the lower left corner.
ReadyNAS Duo/NV/NV+: the pinhole is next to the USB port in the back.
Get a straightened paper clip and depress the hidden switch in the pinhole while the power is off, and then power on the ReadyNAS.
To perform other options such as Skip Volume Check, Tech Support Mode, and Memory Test, this is managed via the Power button.
With the system off, hold down the Power button, and wait for the desired LED flashes.
Release the Power button when the option you desire is active.
Systems with an LCD (NV+) will also display the boot menu item text on the LCD at each stage.
Button to Hold Time to Hold LED flashes Boot Menu Mode
Power 5 seconds 1 Skip Volume Check
Power 10 seconds 2 TFTP Boot
Power 15 seconds 3 Tech Support Mode
Power 20 seconds 4 USB Boot
Power 25 seconds 5 Memory Test
Reset 5 seconds 1 OS Re-install
Reset 30 seconds 2 Factory Default
4. Start the NAS.
3. Start the NAS.
