2pods
Oct 16, 2014Aspirant
ReadyNas Duo Mk2 Blue light booting forever
I added a 2gb Drive to the 2gb drive already in (both OK with the list) and it seemed to be expanding OK, but then it needed to boot and has been like that for about 12 hours. Both drive panel ligh...
mdgm-ntgr
Oct 16, 2014NETGEAR Employee Retired
Are you able to connect the USB disk to your PC and test it?
Also are you able to power down the NAS, remove your disks (label order) and test them using SeaTools?
