satrijoe
Dec 29, 2010Aspirant
ReadyNAS duo not visible to Time Machine
Howdy! I am not a well versed IT user (i.e. dumb) and I am having problems to start using Time Machine and ReadyNAS. I was trying to follow the instructions posted in this article: http://www.read...
nielsNL
Jan 17, 2011Initiate
Hi,
I had the same problem but I finally figured out what the problem was. Maybe it'll help you as well...
- Open Finder, From the menu choose Go - Connect to Server. Type in afp://<readynas>/ReadyNAS (substitute <readynas> with your ReadyNAS IP address).
- Login using username ReadyNAS and the chosen password, I also added the password to the keychain.
- You should now be able to see the ReadyNAS volume in Time Machine.
Hope this helps.
Niels.
Hope this helps.
Niels.
