satrijoe
Dec 29, 2010Aspirant
ReadyNAS duo not visible to Time Machine
Howdy! I am not a well versed IT user (i.e. dumb) and I am having problems to start using Time Machine and ReadyNAS. I was trying to follow the instructions posted in this article: http://www.read...
mdgm-ntgr
Jan 17, 2011NETGEAR Employee Retired
When you select the ReadyNAS (this should be visible in the list of options) as the backup disk you should be prompted to enter the username (ReadyNAS) and password.
If you can't see the ReadyNAS under the list of options on 4.1.7 then perhaps there is a router configuration issue.
A direct-connection would be a good way to determine if there is a router configuration issue. See http://sphardy.com/web/readynas/how-to-direct-connect-to-your-readynas/
