satrijoe
Dec 29, 2010Aspirant
ReadyNAS duo not visible to Time Machine
Howdy! I am not a well versed IT user (i.e. dumb) and I am having problems to start using Time Machine and ReadyNAS. I was trying to follow the instructions posted in this article: http://www.read...
mdgm-ntgr
Dec 19, 2011NETGEAR Employee Retired
You need to look into whether your router supports multicasting and make sure that's enabled. It's possible your router is incompatible unfortunately.
