satrijoe
Dec 29, 2010Aspirant
ReadyNAS duo not visible to Time Machine
Howdy! I am not a well versed IT user (i.e. dumb) and I am having problems to start using Time Machine and ReadyNAS. I was trying to follow the instructions posted in this article: http://www.read...
taylord01
Jan 05, 2012Guide
Hi mdgm. Happy New Year.
So, I've been onto a Broadband Router Advice website and posted there for some steer as to whether this HUAWEI HG532 router does indeed have Multicast settings that I can enable. I've received a response today that points me to the following screen shot, which I have now found on the router : http://screenshots.portforward.com/Huaw ... pgrade.htm
Trouble is, I'm totally out of my depth now I've located the Multicast 'Upgrade' screen. Do I 'enable'. What IP address do I setup? What Port Number should I enter?
Above all, do you think that this 'Multicast Upgrade' setting is likely to be the solution I'm after to have the ReadyNas Duo available as a TimeMachine backup destination via the Router?
Appreciate your help.
