satrijoe
Dec 29, 2010Aspirant
ReadyNAS duo not visible to Time Machine
Howdy! I am not a well versed IT user (i.e. dumb) and I am having problems to start using Time Machine and ReadyNAS. I was trying to follow the instructions posted in this article: http://www.read...
hecarr
Aug 11, 2012Aspirant
Had same problem. Tried Niels solution. Worked like a champ. :D Thanks Niels
- Open Finder, From the menu choose Go - Connect to Server. Type in afp://<readynas>/ReadyNAS (substitute <readynas> with your ReadyNAS IP address).
- Login using username ReadyNAS and the chosen password, I also added the password to the keychain.
- You should now be able to see the ReadyNAS volume in Time Machine.
