yoroen
Oct 18, 2011Aspirant
Readynas DUO partly lost acces
Dear all, Since a while have some issues with the Readynas Duo which was running at that time at least for 2,5 years trouble free (apart of a few reboots in between). Disk 1 was factory fitted (500...
arjoseph1
Oct 26, 2011Tutor
Re-downloading and re-installing the firwmare can also be an option. You may also want to contact support. Once you get a ticket, edit the subject of your post and add it at the end. Thanks!
