nowthennet
Dec 07, 2016Aspirant
ReadyNAS Duo Recycle Bin
ReadyNAS RND2120 V2 Someone has deleted a large folder from one of the shares on the ReadyNAS Duo. Each share has a Recycle bin folder. I have looked in both. The recycle bin folder does contain ...
nowthennet
Thank you StephenB for your fast response.
No, I doubt that I changed the defaults.
When you say "try r-linus on disk 1" are you saying that I need to remove disk 1 and connect it internally in a PC to a SATA port on my motherboard?
When you say "commercial Raid recovery" are you suggesting just googling for a paid-for tool?
Out of interest, why are you suggesting doing this to disk 1? Are disk 1 and disk 2 different?
Thank you
Dec 07, 2016Guru - Experienced User
nowthennet wrote:
When you say "try r-linux on disk 1" are you saying that I need to remove disk 1 and connect it internally in a PC to a SATA port on my motherboard?
Yes, or connect it with a SATA->USB adapter or USB enclosure.
Yes. Some here have used ReclaiMe with success. Though I have not needed any of these tools, so I can't make a recommendation.
The two disks are formatted differently. One has a partition set up with the ext file system that the NAS uses visible. The other has the data mirrored, but it is written directly (with no partition) so it is harder to access. In the 4-bay systems this second disk is a "parity disk". Though the duo is using RAID-1, it still uses the same formatting.
Usually the disk with the partition is disk 1, but depending on the history, it could have gotten reversed.
- nowthennetDec 07, 2016Aspirant
Thank you
