Mathijs
Feb 19, 2013Aspirant
ReadyNAS Duo reset, is my data lost?
I lost my admin password so i had to reset the NAS, unfortunally i holded the reset button to long so the disks are wiped clean.... I have a readyNas Duo with 2x 1Tb disks in raid. After the reset i...
Mathijs
Feb 21, 2013Aspirant
No good backup, otherwise i would not have asked the question.
Thnx for your reply, hopefully it helpes other netgear users.
Also it might reconsider netgear to put such an important action behind this button.
A mistake is easily made in this way.
At this moment i am trying to recover my data with this software: http://www.getdata.com/ hopefully it will work...
