Mathijs
Feb 19, 2013Aspirant
ReadyNAS Duo reset, is my data lost?
I lost my admin password so i had to reset the NAS, unfortunally i holded the reset button to long so the disks are wiped clean.... I have a readyNas Duo with 2x 1Tb disks in raid. After the reset i...
mdgm-ntgr
Feb 24, 2013NETGEAR Employee Retired
If your volume was the capacity of one disk then they were mirrored. However if you were using X-RAID on a Duo (v1) only one disk would have the partition table on it (though the partition table would have been wiped when you wiped the disks).
