no_usernameleft
Jan 13, 2022Aspirant
ReadyNas Duo RND2000-100 won't sync replacement drive.
Model: ReadyNAS Duo [X-RAID] Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] I know this unit is no longer support by Netgear, I get that. But it still works j...
- Jan 17, 2022
For some reason it would not reset on disk one. So I swapped in disk two into the slot and it reset on that one. Then I put the original disk back in and it formatted and synced it without issue.
So basically it's running off the same two disks only with their positions reversed.
I'm in the process of restoring data to the NAS.
Thanks to everyone for their help.
no_usernameleft
Thanks.
Yeah. I've tried re-inserting the drive a couple of times while it was running and stil can't get it to sync. I tried with no formatting and with unallocated space.
Another thing I noticed is that the NAS claims that drive 1 is dead (see screen cap.) So I pulled it and installed in my SATA dock and checked its SMART data with Crystal disk info. It told me the drive was healthy so I was guessing maybe the nas was referring to the RAID set being dead?
The frustrating thing is that the "resync" is not available on the volumes screen. Is it possible that the NAS is not trying to reformat and sync drive 2 because it thinks drive 1 has failed?
Sandshark
Jan 14, 2022Sensei
I think it's quite likely that the declaration of drive 1 being dead is the issue. I had a similar issue on an older NAS where drives were declared dead. It was due to different spin-up times. Does drive 1 come up as dead when you boot with just it installed? That would be quite unusual if you still actually have access to the NAS and its contents.
The only thing I can suggest is booting with just drive 1 until it doesn't come up as dead, then hot inserting drive 2.
- no_usernameleftJan 14, 2022Aspirant
Yes. That's what is odd to me...
- The NAS will not boot with Drive 2 installed. I have to remove Drive 2 and then it will boot off Drive 1, the "dead" drive.
- So Drive 1 is completely bootable on its own in spite of the ReadyNAS saying it is dead.
- I have booted from drive 1 multiple times and it still says it's dead in spite of the NAS contents still being available.
- So I've been pulling everything off of Drive 1 the last few days (even if it was backed up to the cloud) so that I have local copies. And during that time I haven't run into any read/write errors.
I wanted to post here for ideas, but it sounds like I am getting confirmation that this behavior is not correct.
So I am thinking my last ditch effort is to
- Take blank drive 2 and install it as Drive 1 and do a factory reset.
- Then import the NAS configuration, restore it, and reboot.
- Then add the old drive 1 into the drive 2 slot and see if the NAS still thinks it is dead.
- If it is dead then I will add another, new 2 TB drive and sync.
- Then I will copy over all my files I was using for media player.
Sound like a plan?
- StephenBJan 14, 2022Guru - Experienced User
Might be simpler to start with a factory default with only disk 1 installed, and see if that shows the correct disk status.
Then hot-insert a replacement for disk 2.
- no_usernameleftJan 17, 2022Aspirant
