no_usernameleft
Jan 13, 2022Aspirant
ReadyNas Duo RND2000-100 won't sync replacement drive.
Model: ReadyNAS Duo [X-RAID] Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] I know this unit is no longer support by Netgear, I get that. But it still works j...
- Jan 17, 2022
For some reason it would not reset on disk one. So I swapped in disk two into the slot and it reset on that one. Then I put the original disk back in and it formatted and synced it without issue.
So basically it's running off the same two disks only with their positions reversed.
I'm in the process of restoring data to the NAS.
Thanks to everyone for their help.
Jan 14, 2022Guru - Experienced User
Might be simpler to start with a factory default with only disk 1 installed, and see if that shows the correct disk status.
Then hot-insert a replacement for disk 2.
no_usernameleft
Jan 17, 2022Aspirant
