kjellfs
Sep 13, 2015Tutor
ReadyNas Duo RND2000 damaged by lightning
During a bad thunderstorm passing our neighborhood recently my faithful old ReadyNAS Duo was fried by lighting and lost its connection to my local network. I assume that the failure is located to the...
- Sep 13, 2015
Assuming the disks are not damaged...
-buying another duo is an option, the disks can be placed in the new unit (powered down) and it should boot with your data, etc. If you have a scratch disk handy, it is a good idea to use the scratch disk first, and install the same firmware as you were running on the damaged NAS.
-If you were using xraid ,then the freeware program Linux Reader (http://www.diskinternals.com/linux-reader/) can read the data disk on a PC. Usually the data disk is disk 1 (the one on the left). Though sometimes the parity and data disks end up reversed.
I'd try linux reader first, as newer NAS are quite a bit faster than the duo.
Sep 13, 2015Guru - Experienced User
kjellfs
Sep 13, 2015Tutor
Thank you for good advice. I will follow your suggestion and go with the Linux Reader first, it seems to be the easiest way (I wasn't aware of this program). As I am away from home I'll have to wait until next weekend before doing.
Wish me luck!!:smileyhappy:
- StephenBSep 14, 2015Guru - Experienced User
I hope the disks are still ok.
Let us know how it goes.
The RN102, RN202, and RN312 would all good replacements for your duo. As you might expect, the RN102 is the least capable/least expensive; the RN312 is the most capable/most expensive.
- kjellfsSep 18, 2015Tutor
Hi there!
Your advice worked fine, StephenB. I managed to read and copy the data disk (WD20EARS 2TB) with the Linus Reader. Initially I installed the HDD in a USB cabinet with a dedicated power supply, but the USB 3 connection to a desktop PC was unable to read any data from the disk other than the name of the disk. Only after connecting the data disk directly to the same PC the files could successfully be read and copied to a backup disk.
Thanks again for good advice.
Best
Kjell
