itm
Nov 05, 2016Tutor
ReadyNAS Duo RND2000 not booting
I removed the drives from my ReadyNAS Duo a few days ago and left it turned off. Now it won't complete the boot sequence. The blue power LED flashes on and off continually, and all four of the green ...
- Nov 05, 2016
itm wrote:
... the pattern on the green LED flashing is: all 3 LEDs flash slowly 3 times, then quickly 3 times. This cycle repeats ad infinitum
http://home.bott.ca/webserver/?p=324
Corrupt root partition. You can confirm this with RAIDar. http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar
itm
Nov 05, 2016Tutor
- StephenBNov 05, 2016Guru - Experienced User
- itmNov 05, 2016Tutor
Thanks - I've now tried rebooting it with a single unpartitioned disk and it is fine again. I didn't realise that the machine doesn't start up at all if it doesn't like one of the disks that's installed.
- FramerVNov 06, 2016NETGEAR Employee Retired
Hi itm,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
