Wristel's avatar
Wristel
ReadyNAS Duo RND2000 several questions of not starting up, Raid0 and removing one disc....
Hi!
My NAS stopped working earlier this week... shutted it down sinsw it made a whining sound and now it wont start...
It makes a clicking sound on startup (like reader arm moving) from one of the disks but i cant hear/feel wich one!!
Runs it in Raid0.. bought is as a v2 so i could run JBOD but it was just a rnd2000n2 not a readyNASv2 with the big fan on the back!
here are the questions:
1. can i remove just one disc to locate wich is clicking without damage the content on the discs??
2. could it be some othe fault?...
don't wind down on startup...
powerbutton blinking...
don't shut down when i hold down the powerbutton!
....but when i push the powerbutton it winds donwn, the power led is "pulsating" and disc1 led is blinking..
3. how do i manage the NAS best since there is no RAIDiator for OsX?!?
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Wristel,
    Welcome to the community!
    It is not safe to remove one of the disks from a RAID 0 configuration, This RAID level has no redundancy. When booting up the NAS, both disks should always be inserted to it.
    RAID 0 distributes data across multiple disks, resulting in improved disk performance compared to systems that do not use RAID formatting. The total capacity of your storage system equals the capacity of the smallest of your disk drives times the number of disks. RAID 0 is available on volumes consisting of two or more hard disks.
    The problem could be one of the disks is faulty, did you configure the email alerts in the FrontView? It is so you will receive reports including disk errors. For now I do not recommend removing any of the disks.
    RAIDiator is what you call the firmware of the NAS, I apologize but it did not make sense when you said "there is no RAIDiator for OSX", you must be referring to RAIDar which has version for Mac OS X. Its purpose is to just detect the NAS to show it's current IP address and status. I suggest download and install it to see if your computer sees it and if it is visible on the network.
    Hope this help! I look forward to your update.
  • StephenB's avatar
    EDIT-JennC beat me, so there is some overlap in our responses.
    -You'll need to risk pulling the plug if it won't shut down.
    -You say you are running RAID-0 - do you have two data volumes  (C and D) or just one (C)?  If you do only have one volume with RAID-0, a disk failure means you've lost the complete disk volume. Please let us know how many volumes (and what firmware the NAS was running).
    -A clicking sound is almost certainly a bad disk.  The only other option would be a fan bearing.  You can rule out the fan bearing by starting the NAS with both disks removed.
    -RAIDar 4.3.8 is available for OSX - you can find the download here: http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Mac_4_3_8.dmg
    Assuming a bad disk - and only one data volume (and no backup):
    You could use a data recovery service to try to get your data back.  That would be expensive (usually the cost depends on how much labor is needed).  Netgear offers data recovery, there are other reliable services.  Seagate offers their own service, Western Digital lists some services on their web site.  There are some scams out there, so be careful if you pick a different service.
    You could also purchase a RAID recovery software package.  These are also generally quite expensive.
    The third option is to attempt to "clone' the bad drive - using a cloning program to copy all the readable sectors to a new disk.  If you want to keep your other data recovery options open, clone both drives.  Then install the clones in the NAS (in the right order) with the NAS powered down, and see if it boots.  There usually is still data corruption, but you might get the bulk of the data back.
    None of these methods are certain (and if the disk has totally failed, you've certainly lost your data).  You might begin by setting a ceiling on how much money and effort you are prepared to spend to get the data back.
ProSupport for Business
