Wristel
Dec 11, 2015Aspirant
ReadyNAS Duo RND2000 several questions of not starting up, Raid0 and removing one disc....
Hi! My NAS stopped working earlier this week... shutted it down sinsw it made a whining sound and now it wont start... It makes a clicking sound on startup (like reader arm moving) from one o...
Wristel
Dec 12, 2015Aspirant
Thanks for all help...
will take on the Duo v1 some day...
the rnd4000 is up and running on Raid-X and latest firmware... only problem (probably my fault) is that i cant find the data on the USB drive that i had connected to the Duo..
Frontviw finds it ant that it har XXXGB used and XXXXGB free... but Finder dont see the folders/files just the "USB_HDD_2" (named it the same as it was on the Duo) folder/volume... hope its not gone and that its just me and my
incompetence.. :(
any ideas why?
Wristel
Dec 16, 2015Aspirant
i have copied the content to my iMac but having problem to get the rnd4000 to accept my 2TB egate USB drive...
what filesystems can i use for the USB drive so the rnd4000 can use it?..
tried ex-FAT so i could use both my iMac and my PC laptop but Frontwiev says "No Filesystem" en the USB drive.. cant use FAT32 due to large files...
