johnnyartois
Jun 21, 2022Aspirant
ReadyNAS Duo RND2210v2
Device wasn't booting up, removed discs, still not booting. Blue light flashing and fan running continually. Green lights flash twice then three times in quick succession. RAIDAR 4.3.8 locates the de...
- Jun 23, 2022
johnnyartois wrote:
Thanks but the link doesn't work "not found"
Sorry - I left off the .pdf at the end. It's fixed now.
johnnyartois
Jun 23, 2022Aspirant
Jun 23, 2022Guru - Experienced User
- johnnyartoisJun 23, 2022Aspirant
Thanks for your help Stephen, I've restored the unit to the latest firmware. RAIDar choses when to connect and drops frequently, so I'll use a cable for a more reliable connection when required. Just need to find a replacement HDD for redundancy. Is the solution for ERR_SSL_VERSION_OR_CIPHER_MISMATCH just to use internet explorer?
- StephenBJun 23, 2022Guru - Experienced User
It's one option.
You can also install an older version of firefox (94.0.2 works) and configure that to not autoupdate. Some have gotten the portable version (likely so they can continue to use current Firefox for general use).
The third option is to enable ssh on the NAS, and modify virtual.conf to allow http access (not encrypted) to Frontview.
More details on all of this is here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
