MacNasMan
Jan 09, 2024Guide
ReadyNAS Duo still running!
-Hello everyone, I just wanted to say how pleased I am that my old ReadyNAS Duo circa 2010, maybe earlier, can't remember when I bought it, is still running strong! I've had a lot of stuff happen in ...
- Jan 09, 2024
My own Duo is about the same age, and is also still working. It doesn't have the capacity for my data now, so it is a secondary backup.
(RAID isn't enough to keep your data safe, so you do still need a backup on another device).
MacNasMan wrote:
The only issue is accessing the Front view, only old versions of browsers allow this kind of access.
The current version of FireFox will work if you set security.tls.version.min to 1 (browse to about:config and search for the setting).
There's also the mod here:
Jan 09, 2024Guru - Experienced User
