MacNasMan
Jan 09, 2024Guide
ReadyNAS Duo still running!
-Hello everyone, I just wanted to say how pleased I am that my old ReadyNAS Duo circa 2010, maybe earlier, can't remember when I bought it, is still running strong! I've had a lot of stuff happen in ...
- Jan 09, 2024
My own Duo is about the same age, and is also still working. It doesn't have the capacity for my data now, so it is a secondary backup.
(RAID isn't enough to keep your data safe, so you do still need a backup on another device).
MacNasMan wrote:
The only issue is accessing the Front view, only old versions of browsers allow this kind of access.
The current version of FireFox will work if you set security.tls.version.min to 1 (browse to about:config and search for the setting).
There's also the mod here:
saudade
Jan 12, 2024Apprentice
Mine is still ticking too. Got mine around 2009 as I recall. Took it offline when I got a WD EX4 (much larger capacity). Brought back online last year as my WD is now EOL to back up the EX4. Had the usual issues with SSL. Applied the "fix" and all is well.
