MacNasMan
Jan 09, 2024Guide
ReadyNAS Duo still running!
-Hello everyone, I just wanted to say how pleased I am that my old ReadyNAS Duo circa 2010, maybe earlier, can't remember when I bought it, is still running strong! I've had a lot of stuff happen in ...
- Jan 09, 2024
My own Duo is about the same age, and is also still working. It doesn't have the capacity for my data now, so it is a secondary backup.
(RAID isn't enough to keep your data safe, so you do still need a backup on another device).
MacNasMan wrote:
The only issue is accessing the Front view, only old versions of browsers allow this kind of access.
The current version of FireFox will work if you set security.tls.version.min to 1 (browse to about:config and search for the setting).
There's also the mod here:
EngineerRS
May 03, 2024Aspirant
It’s good to see older models still going. I have a Duo v1 think 2008. It’s been working well until I tried to but a bigger disk in. Does anyone know the meaning of disk LEDs blinking alternatively? Blue power lights goes off after a split second and unable to switch it off without pulling the power plug. Fan come on and no detection in Raidar. Thanks in advance.
- StephenBMay 03, 2024Guru - Experienced User
EngineerRS wrote:
It’s been working well until I tried to but a bigger disk in.Disk size is limited to 2 TB. Many 2 TB drives are SMR, and they should be avoided.
EngineerRS wrote:
Does anyone know the meaning of disk LEDs blinking alternatively?LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code. Current error codes: 1 - Vendor mismatch 2 - No disks detected 3 - Bad contents on root partition of disks 4 - Flash error 5 - Unsupported RAID configuration- saudadeMay 03, 2024Apprentice
Mine still has the Seagate Barracuda Green drives in it from 2011!!
