patientJoe
Aug 08, 2012Aspirant
ReadyNAS Duo stopped booting - how can i escalate? #18821912
Hi, My ReadyNAS Duo stopped working since mid june and the tech support via email is not getting anywhere. I approved NETGEAR Remote Access Policy in mid July and had to setup port forwarding and p...
patientJoe
Thank you all for nudging Netgear support - i have now received a confirmation that my issue has been escalated to L3 :)
I do not understand this sentence on their reply:
"You do not need to reply for now so that the case will not de-escalate back to level 2 bin."
Does this mean replying to this case number thread will de-escalate my problem back to L2???
For L3 to remote access my ReadyNAS duo drive they need the WAN IP address of my router. The router IP is not a static IP so its change is out of my control. Every so often i check http://www.subnetonline.com/ and update Netgear if my IP changes!
So should I keep updating them or not? Or am i missing something fundamental?
- Apr 15, 2024Retired_Member
