Eddie1's avatar
Eddie1
ReadyNAS DUO System Partition Full #19755076
After a failed upgrade attempt I am left with a system partition that is full. I this state I can not either upgrade of downgrade.
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/hdc1 2031872 2002272 29600 99% /
tmpfs 16 0 16 0% /USB
/dev/c/c 970385648 554221584 416164064 58% /c
I really need to find and remove the files left from the failed upgrade. I do have terminal access if necessary, I just have no clue where the artifacts from this failure would be.
Thanks, E
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    As I mentioned in your other thread you should contact NetGear support and post your case number.
  • Solved, tls.log file gone nuts... removed and went from 99% to 23%
ProSupport for Business
