disney_cjd
Dec 16, 2016Tutor
ReadyNAS Duo. Today wont power on (was shutdown fine via Frontview) - options please?
Dear all As well as having the flu I am crying at the NAS. I have an ReadyNAS Duo v1 from about 2012 ish I guess. It has 2 x 2TB drives at about 65 percent full. My Zigor UPS died yesterday. ...
JennC
Dec 16, 2016NETGEAR Employee Retired
Hello disney_cjd,
When you say it will not start, does that mean it does not completely boot up or it will not power on at all that there is no LED lighting up?
If there is an LED lighting up but the disk and power LEDs are flashing, check if RAIDar detects the NAS. If it does, it will show the status of the NAS and its LAN IP address. Power LED blinks when NAS does not completely boot up, it is either NAS is not able to get an IP address from the network or one or both disks are having some trouble. Both fault disks is possible which is why we always strongly recommend to backup your data, after all, it is not wise to store important data to just one storage.
The replacement you may purchase is RN10200 which more advanced than your Duo. However, you cannot simply insert the disk to the new chassis as the new chassis has a different OS. Your first goal here is to retrieve the data.
Let me know first the status of the NAS that shows on RAIDar. If that does not detect the NAS, hook up the NAS straight to the computer and let RAIDar detect it.
disney_cjd
Dec 16, 2016Tutor
Thank you. Sorry, I should have been clear. It's not powering at all. So I press the power button and nothing. No power, no led.
- JennCDec 16, 2016NETGEAR Employee Retired
Hello disney_cjd,
Is this using a power brick? If so, check the power brick if its light is on. If it is just a simple power cable like the one we use with desktop computers, then try using another power cable to test.
- disney_cjdDec 18, 2016Tutor
Thank you. It was the power brick! So all working. NOw backing up and going to sell it.... Is there a palce on here we can sell?
- StephenBDec 18, 2016Guru - Experienced User
disney_cjd wrote:
Is there a place on here we can sell?
There is no dedicated sub-forum for that anymore, but you could post the offer on this thread (or a new one with a link), and perhaps someone will PM you.
