seanmt
Feb 27, 2011Aspirant
ReadyNAS Duo Upgrade to 2TB Hard Drives
Currently I am running with two 1TB HDD's but I need more capacity so have bought two 2TB HDD's. Current HDD's -------------------- Disk 1 Seagate ST31000528AS Disk 2 Seagate ST31000528AS New...
bendraper
Jul 15, 2011Aspirant
Thanks mdgm
Reset the browers cache and everything worked fine - thanks for your time
Although has anyone else encountered the Firefox issue the asking you to create a security exemption for the https: etc becuase the cert is self signed, and then not letting you add it becuase it is a vaid cert?
how bizzar
Thanks for you time
Kind regards
Ben
how bizzar
Thanks for you time
Kind regards
Ben
