seanmt
Feb 27, 2011Aspirant
ReadyNAS Duo Upgrade to 2TB Hard Drives
Currently I am running with two 1TB HDD's but I need more capacity so have bought two 2TB HDD's. Current HDD's -------------------- Disk 1 Seagate ST31000528AS Disk 2 Seagate ST31000528AS New...
PapaBear1
Jul 16, 2011Apprentice
Anytime you reset the NAS or upgrade to a new version of RAIDiator, you will probably see that Firefox warning. Just check the box to make the exception permanent and you won't see the warning for a while. You also get a warning in IE9, and it turns the address block red. There is no permanent exception in IE9 that I can find. They don't like it because the NAS has a self signed certificate. However, why should Netgear pay for a certificate for these units, when they are always connected to an internal network? (I don't think the certificates are cheap either).
