kennethmacleod
Jul 10, 2010Aspirant
ReadyNas Duo USB Share - Write-Protected
Hi All, I am looking for some help. I have a Netgear ReadyNas NV+ running perfectly. I also have a Netgear ReadyNas Duo running perfectly. I have a Western Digital 2TB USB drive which I have plugge...
B52hbuff
We may be running into a similar problem.
viewtopic.php?f=31&t=41278
My recommendation is that you unplug the usb drive from the duo, plug the drive in again, then verify you can write to the usb drive. In windows, navigate to \\nasname\USB_HDDn\... and copy a file there. If you can write to it, then start your backup.
So I think I'm at a point where this workaround 'works' for me... curious to see if it 'works' for you. Then maybe we could figure out a better solution, or more troubleshooting.
