kennethmacleod
Jul 10, 2010Aspirant
ReadyNas Duo USB Share - Write-Protected
Hi All, I am looking for some help. I have a Netgear ReadyNas NV+ running perfectly. I also have a Netgear ReadyNas Duo running perfectly. I have a Western Digital 2TB USB drive which I have plugge...
B52hbuff
Jul 11, 2010Aspirant
Ok, I wasn't advertising this as a permanent fix, but at least we know the two issues are similar.
Does your external drive have any settings to disable the power management? Mine doesn't...
I'm hoping Netgear can address the issue with a firmware upgrade...
