kennethmacleod
Jul 10, 2010Aspirant
ReadyNas Duo USB Share - Write-Protected
Hi All, I am looking for some help. I have a Netgear ReadyNas NV+ running perfectly. I also have a Netgear ReadyNas Duo running perfectly. I have a Western Digital 2TB USB drive which I have plugge...
mdgm-ntgr
Oct 28, 2010NETGEAR Employee Retired
Ah, a USB disk sleep timer. Hook the disk up to a PC and use the vendor utility to disable the sleep timer on the disk. Hope this helps.
If the vendor utility can't disable the sleep timer then there may not be much that can be done.
Edit: I guess it depends too if ewok can get something to be done on the ReadyNAS side to help things or not.
