Retak
Jan 04, 2017Aspirant
ReadyNAS Duo V1 - Boot Problem
At some point during the day yesterday it was noticed that our ReadyNAS Duo could no longer be accessed via wireless connection. I did not set up this system and don't know what type of RAID setup w...
- Jan 10, 2017
Hello Retak,
I understand you have been contacted by one of the support team.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Jan 04, 2017Guru - Experienced User
Retak wrote:
* When I tried to boot the NAS with only disc B present, the following happened:
- The power botton light stayed on, and the other LEDs blinked rapidly three times and then then slowly twice.
- RAIRar said no discs were detected.
* When I tried to boot the NAS with only disc A present, the following happened:
- The power botton light blinked at a medium rate and the other four LEDs blinked rapdily three times and then slowly three times.
- RAIRar said there was a corrupt root.
The LED decoder ring is here: http://home.bott.ca/webserver/?p=324
The blinking patterns match RAIDar.
When you booted with disc B, was it in slot 2? If not, perhaps try that again, using slot 2.
One of the disks is the primary disk (normally that would be disk A, but that depends on the history). The second disk is a "parity disk" - a mirror in the case of the duo (assuming RAID-1 or XRAID). But there's a catch - the data volume is mirrored to an area of the disk that has no partition. That makes recovery from disk B more difficult.
Was disk A clicking in the Duo? Or just the PC?
One option is to contact Netgear and ask them about a data recovery contract. Data Recovery is expensive (US pricing starts at $200) and it is not guaranteed. But they of course have the most expertise.
What recovery program were you using? Some have used R-Linux for Windows, other's ReclaiMe. It might be worth trying both. Cloning the disk(s) and working with the clones might be safest.
Retak
Many thanks Stephen!
I had seen that decoder ring (this info is hard to find) and the blinking codes did indeed match.
Yes, it was in slot 2. I can't remember if I tried it in slot 1 and I don't know if it's a good idea.
Just the PC. At least I couldn't hear it clicking while it was in the enclosure, but now that I think about it, I don't think I listened for it with the door open.
I had the most success with ReclaiMe. I tried two other commercial programs, but they wouldn't do anything without both discs. ReclaiMe was willing to scan just the one disc (B) and it did pick up at least some files, but it kept hanging up. I was using a SATA to USB adapter and the disc also occasionally got disconnected. I'm not sure why (I tried two adapters), but it was worrisome. I've contacted ReclaiMe to ask about this problem and if they can get data off a single disc.
I have not tried R-Linux, but I will look at that.
Yeah, I'd like to do this. Do you know if it's possible to do so within the Windows environment? I don't have a Linux computer handy, although I could set up a partition if needed. I have minimal experience with Linux commands, however.
I will look into this as well, as it's very important -- thanks!
Thanks again!
