Retak
Jan 04, 2017Aspirant
ReadyNAS Duo V1 - Boot Problem
At some point during the day yesterday it was noticed that our ReadyNAS Duo could no longer be accessed via wireless connection. I did not set up this system and don't know what type of RAID setup w...
- Jan 10, 2017
Hello Retak,
I understand you have been contacted by one of the support team.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Jan 04, 2017Guru - Experienced User
start with my.netgear.com and then ask (perhaps in a support request). @mdgm can probably facilitate a connection if that doesn't work.
JennC
Jan 10, 2017NETGEAR Employee Retired
Hello Retak,
