Adalbert63
Apr 03, 2018Aspirant
ReadyNAS Duo V1 - Boot Problem
I have a problem with my NAS. I have a ReadyNAS Duo v1 with 2 disk with capacity 2TB and RAID system. After weekend disk don't start - RAIDar said: "System booting", blue LED flash and nothing...
Apr 03, 2018Guru - Experienced User
Try powering down, and removing the disks (labeling them by slot). Then power up again diskless. Let us know if RAIDar detects the NAS with a no-disk status.
Was the NAS powered down cleanly, or was the power lost (or disconnected)?
Adalbert63
After removed all disk, server started OK and RAID'a said "no disk".
- StephenBApr 03, 2018Guru - Experienced User
The next step is to test the disks. The best approach is to connect the to a windows PC (either with SATA or a USB/SATA adapter/dock). Then test them with vendor tools - Seatools for Seagate; Lifeguard for Western Digital.
Don't reformat or initialize the disks with Windows. It won't recognize the format, but the vendor tools will find the disks anyway.
If you don't have an up to date backup, you can offload the data by installing r-linux for windows on the PC. http://www.r-studio.com/free-linux-recovery/ It will only see the data files on one of the two disks (almost always disk 1).
- Adalbert63Apr 03, 2018Aspirant
Unfortunately link http://www.r-studio.com/free-linux-recovery/ don't work.
If i connect one of disk to Linux, it is possible to copy my data ?
- mdgm-ntgrApr 03, 2018NETGEAR Employee Retired
Were you using X-RAID?
If you were using Flex-RAID, what volumes had you created and which RAID level were they using?
