perky
Sep 06, 2016Aspirant
ReadyNAS Duo v1 - Full OS Partition?
I'm new to the community and seeking your help in resurrecting my ReadyNas Duo V1. Its behaviour became increasingly erratic recently and now I've lost access to the shares. Having researched th...
mdgm-ntgr
Sep 08, 2016NETGEAR Employee Retired
# /sysroot/bin/df -h
# /sysroot/bin/df -i
# /sysroot/usr/bin/du -csh /sysroot/var/*
# /sysroot/usr/bin/du -csh /sysroot/var/log/*
Normally we copy log files onto the data volume before emptying them just in case the logs contain information that may be useful for troubleshooting other issues.
- perkySep 08, 2016Aspirant
Filesystem Size Used Avail Use% Mounted on
rootfs 7.7M 6.5M 1.3M 83% /
/dev/root 7.7M 6.5M 1.3M 83% /
tmpfs 16k 0 16k 0% /dev/shm
/dev/hdc1 1.9G 2.0G 64k 100% /sysroot# /sysroot/bin/df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
rootfs 2048 250 1798 13% /
/dev/root 2048 250 1798 13% /
tmpfs 7073 1 7072 1% /dev/shm
/dev/hdc1 128000 10969 117031 9% /sysroot# /sysroot/usr/bin/du -csh /sysroot/var/*
16k /sysroot/var/backups
47M /sysroot/var/cache
16k /sysroot/var/ftpd
38M /sysroot/var/lib
16k /sysroot/var/local
32k /sysroot/var/lock
1.2G /sysroot/var/log
16k /sysroot/var/mail
16k /sysroot/var/netatalk
16k /sysroot/var/opt
544k /sysroot/var/run
371M /sysroot/var/spool
16k /sysroot/var/tmp
32k /sysroot/var/www
48k /sysroot/var/yp
1.6G total# /sysroot/usr/bin/du -csh /sysroot/var/log/*
11M /sysroot/var/log/LeafP2P.log
0 /sysroot/var/log/LeafP2P.log.old
0 /sysroot/var/log/LeafP2P.log.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old.old
0 /sysroot/var/log/LeafP2P.log.old.old.old.old.old.old.old.old
51M /sysroot/var/log/auth.log
80k /sysroot/var/log/cron.log
64k /sysroot/var/log/cups
8.4M /sysroot/var/log/daemon.log
16k /sysroot/var/log/ddns
0 /sysroot/var/log/debug
0 /sysroot/var/log/dekoh_access.log
0 /sysroot/var/log/dekoh_access.log.old
0 /sysroot/var/log/dekoh_access.log.old.old
0 /sysroot/var/log/dekoh_access.log.old.old.old
0 /sysroot/var/log/dekoh_error.log
0 /sysroot/var/log/dekoh_error.log.old
0 /sysroot/var/log/dekoh_out.log
0 /sysroot/var/log/dekoh_out.log.old
0 /sysroot/var/log/dekoh_out.log.old.old
16k /sysroot/var/log/dmesg
32k /sysroot/var/log/exim
1.1G /sysroot/var/log/frontview
0 /sysroot/var/log/fsck.log
4.5M /sysroot/var/log/kern.log
16k /sysroot/var/log/ksymoops
0 /sysroot/var/log/lpr.log
0 /sysroot/var/log/mail.log
4.6M /sysroot/var/log/messages
0 /sysroot/var/log/mt-daapd.log
0 /sysroot/var/log/mt-daapd.log.old
0 /sysroot/var/log/netatalk.log
0 /sysroot/var/log/netatalk.log.old
0 /sysroot/var/log/netatalk.log.old.old
0 /sysroot/var/log/netatalk.log.old.old.old
0 /sysroot/var/log/netatalk.log.old.old.old.old
16k /sysroot/var/log/ntpstats
0 /sysroot/var/log/raidiator_version
0 /sysroot/var/log/raidiator_version.old
192k /sysroot/var/log/samba
0 /sysroot/var/log/slimserver.log
16k /sysroot/var/log/squeezecenter
16M /sysroot/var/log/syslog
256k /sysroot/var/log/upnp-av.log
0 /sysroot/var/log/upnp-av.log.old
0 /sysroot/var/log/upnp-av.log.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old.old
0 /sysroot/var/log/upnp-av.log.old.old.old.old.old.old.old.old.old
0 /sysroot/var/log/user.log
1.2G total# /sysroot/usr/bin/du -csh /sysroot/var/log/frontview/*
16k /sysroot/var/log/frontview/access.log
0 /sysroot/var/log/frontview/apache-ssl.pid.old
16k /sysroot/var/log/frontview/backup
16k /sysroot/var/log/frontview/command.log
0 /sysroot/var/log/frontview/disk_smart_2016_05_29.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_05.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_12.log
0 /sysroot/var/log/frontview/disk_smart_2016_06_20.log
0 /sysroot/var/log/frontview/disk_smart_2016_07_03.log
0 /sysroot/var/log/frontview/disk_smart_2016_07_19.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_01.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_14.log
0 /sysroot/var/log/frontview/disk_smart_2016_08_21.log
16k /sysroot/var/log/frontview/disk_smart_2016_08_30.log
16k /sysroot/var/log/frontview/disk_usage.log
0 /sysroot/var/log/frontview/disk_usage.log.old
0 /sysroot/var/log/frontview/ecounter_2016_08_30_2209.log
0 /sysroot/var/log/frontview/ecounter_2016_08_30_2241.log
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2030.log
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2030.log.old
0 /sysroot/var/log/frontview/ecounter_2016_08_31_2112.log
0 /sysroot/var/log/frontview/enclosure.log
0 /sysroot/var/log/frontview/enclosure.log.old
1.1G /sysroot/var/log/frontview/error.log
16k /sysroot/var/log/frontview/memory.log
0 /sysroot/var/log/frontview/memory.log.old
0 /sysroot/var/log/frontview/partitions_2016_05_29.log
0 /sysroot/var/log/frontview/partitions_2016_06_05.log
0 /sysroot/var/log/frontview/partitions_2016_06_12.log
0 /sysroot/var/log/frontview/partitions_2016_06_20.log
0 /sysroot/var/log/frontview/partitions_2016_07_03.log
0 /sysroot/var/log/frontview/partitions_2016_07_19.log
0 /sysroot/var/log/frontview/partitions_2016_08_01.log
0 /sysroot/var/log/frontview/partitions_2016_08_14.log
0 /sysroot/var/log/frontview/partitions_2016_08_21.log
0 /sysroot/var/log/frontview/partitions_2016_08_30.log
0 /sysroot/var/log/frontview/raid_config_2016_05_29.log
0 /sysroot/var/log/frontview/raid_config_2016_06_05.log
0 /sysroot/var/log/frontview/raid_config_2016_06_12.log
0 /sysroot/var/log/frontview/raid_config_2016_06_20.log
0 /sysroot/var/log/frontview/raid_config_2016_07_03.log
0 /sysroot/var/log/frontview/raid_config_2016_07_19.log
0 /sysroot/var/log/frontview/raid_config_2016_08_01.log
0 /sysroot/var/log/frontview/raid_config_2016_08_14.log
0 /sysroot/var/log/frontview/raid_config_2016_08_21.log
0 /sysroot/var/log/frontview/raid_config_2016_08_30.log
16k /sysroot/var/log/frontview/smart_errors_hdc
0 /sysroot/var/log/frontview/smart_errors_hdc.old
16k /sysroot/var/log/frontview/smart_errors_hde
0 /sysroot/var/log/frontview/smart_errors_hde.old
16k /sysroot/var/log/frontview/spool.err
0 /sysroot/var/log/frontview/spool.err.old
16k /sysroot/var/log/frontview/spool.log
0 /sysroot/var/log/frontview/spool.log.old
0 /sysroot/var/log/frontview/spool.log.old.old
0 /sysroot/var/log/frontview/status.log-new
0 /sysroot/var/log/frontview/status.log-new.old
0 /sysroot/var/log/frontview/status.log-new.old.old
0 /sysroot/var/log/frontview/status.log-old
0 /sysroot/var/log/frontview/status.log-old.old
0 /sysroot/var/log/frontview/status.log-old.old.old
0 /sysroot/var/log/frontview/status.log-old.old.old.old
1.1G total- perkySep 08, 2016Aspirant
So: /sysroot/var/log/frontview/error.log at 1.1G would appear to be the biggest. Is this the likely culprit? What is the recommended next steps. Really appreciate your help here. Thanks so much.
The error log is full of "File does not exist: /frontview/ui/resource/html/presence"
