alanmusic
Jun 02, 2013Aspirant
ReadyNas Duo v1 - what does these lights mean?
what does this mean: Power light on. All other lights flashing two long and three short over and over?
Jun 03, 2013Guru - Experienced User
If you have the ability to connect the drive to a PC (via USB adapter or SATA), you should test it with vendor tools (seatools for seagate, lifeguard for western digital).
Is this your initial install?
