Giusi71
Mar 04, 2013Aspirant
Readynas duo v1 + neotv550 no streaming
I use a readynas duo v1 with my media files, connected to my network. My hd player is the neotv 550. It used to work very well, but suddenly, it doesn't work any more. Indeed the ntv550 is not able to...
Mar 05, 2013Guru - Experienced User
Is the NTV550 using wifi or powerline to connect, or is it using wired LAN?
Can you reach the NTV550's web page? If you enable DLNA on the duo, does the NTV see that?
Also, is your media in the built-in Media share on the Duo, or is it somewhere else? (there have been issues reported here with permissions on the built-in share).
One option is to factory reset the NTV550, and see if that solves it (a pain, but at least there is no data loss to worry about).
