Giusi71
Mar 04, 2013Aspirant
Readynas duo v1 + neotv550 no streaming
I use a readynas duo v1 with my media files, connected to my network. My hd player is the neotv 550. It used to work very well, but suddenly, it doesn't work any more. Indeed the ntv550 is not able to...
Giusi71
Mar 05, 2013Aspirant
Giusi71 wrote: I see the dlna folder but the folder icon is not saying "hostname:Readynas xxx", but instead "myPCWindows7hostname:username of windows session" is it normal ?
Thank you again for your very helpfull support but I am becoming mad with that issue :cry:
I seen somewhere in the forum that the version 1.0.25 of ReadyDLNA might be an issue. Woukd it be possible to install an older version to see if this will solve my problem ?
Effectively my computer was switched on when i did the dlna test. But now that I switched off my computer, i can not see the readynas dlna folder. There is no dlna folder at all. Therefore i think the issue is coming from the readydlna add-on version 1.0.25.
How can i revert to an older version ? I currently use raidiator ver 4.1.10. Thank you for your help
