Giusi71
Mar 04, 2013Aspirant
Readynas duo v1 + neotv550 no streaming
I use a readynas duo v1 with my media files, connected to my network. My hd player is the neotv 550. It used to work very well, but suddenly, it doesn't work any more. Indeed the ntv550 is not able to...
Mar 05, 2013Guru - Experienced User
Well, the NTV sees DLNA, but not from the ReadyNAS. So we know that. We also know that the connection between the NAS and the PC works. The core issue is that you can't see media from any CIFS or NFS ReadyNAS share on the NTV.
As far as DLNA itself goes, you don't need it with the NTV anyway. So I would turn DLNA support back off in the NTV. Unless you need DLNA with some other device you have, turn it off in the NAS as well.
When you rescanned the network, did you see any ReadyNAS folders (either with the ReadyNAS host name or its IP address)? Did you try setting up access to testfolder using the IP address or the host name?
Also, did you make any recent changes to your home network (install new switches, routers, etc)?
You can try downgrading to 4.1.9 Just download the image from here: http://www.readynas.com/?p=6480 and manually install it via Frontview.
