Giusi71
Mar 04, 2013Aspirant
Readynas duo v1 + neotv550 no streaming
I use a readynas duo v1 with my media files, connected to my network. My hd player is the neotv 550. It used to work very well, but suddenly, it doesn't work any more. Indeed the ntv550 is not able to...
Giusi71
Mar 05, 2013Aspirant
StephenB wrote: When you rescanned the network, did you see any ReadyNAS folders (either with the ReadyNAS host name or its IP address)? Did you try setting up access to testfolder using the IP address or the host name?
Also, did you make any recent changes to your home network (install new switches, routers, etc)?
You can try downgrading to 4.1.9 Just download the image from here: http://www.readynas.com/?p=6480 and manually install it via Frontview.
When I scanned the network I saw no readynas folder. I scanned using the hostname and the ip address with the same result. The same for the testfolder. It is as if the readynas was disconnected, but I can access it from my pc.
As i remember i made no change to my home network apart opening a port in my router for an application. But I tried alreasy to close this port without success.
I will try do downgrade.
Than you for your helpful support.
