2trees
Feb 11, 2014Aspirant
ReadyNAS Duo V1 ADD TO
My current unit is at max. drive capacity ie, 2x2TB. Can and how should I add an additional identical unit, to facilitate the dedication of this additional unit to media,and the original to backup of...
vandermerwe
Feb 11, 2014Master
I think you are asking whether you can get another NAS and put some of your existing data onto it.
Of course, although I would not get an identical unit. The duo v1 is now old and, relatively speaking, slow.
You need to consider:
How much data you'll accumulate in the next few years.
Whether you'll need the unit just as a storage server or whether you'll be streaming or transcoding.
How you will backup your data.
I would look at the new Readynas range, plenty of info around.
