2trees
Feb 11, 2014Aspirant
ReadyNAS Duo V1 ADD TO
My current unit is at max. drive capacity ie, 2x2TB. Can and how should I add an additional identical unit, to facilitate the dedication of this additional unit to media,and the original to backup of...
Feb 11, 2014Guru - Experienced User
Hey, your join date is my mom's birthday.
Available funds is usually an issue :) Twin units can help, I wasn't meaning to dismiss that idea.
If you just want to add a newer 2-bay unit with similar features (and better performance), you should look at the RN102. You can find used equipment, but of course you are taking chances there. A used NV+ v1 would take your older 750GB disks w/o data loss (assuming they were from the duo).
