2trees
Feb 11, 2014Aspirant
ReadyNAS Duo V1 ADD TO
My current unit is at max. drive capacity ie, 2x2TB. Can and how should I add an additional identical unit, to facilitate the dedication of this additional unit to media,and the original to backup of...
Feb 12, 2014Guru - Experienced User
The RN102 and the duo v1 can coexist on the same network without problems. You can also migrate your data over the network between the two devices.
There should be no issues with the EVA9100, or with access from your PC.
