joepublic1
Apr 22, 2013Aspirant
ReadyNAS Duo v1 Boot Problem
Twice now my ReadyNAS Duo does not complete boot sequence. The blue power on light continues to flash. FrontView is not accessible, the shares are not accessible but the device responds to ping. Nothi...
gopterman
May 05, 2013Aspirant
Did you ever get anywhere with this?
It sounds like my Duo is having identical problems although mine never gets to a point where I can see what's going on .....
Power light flashes continually at just under 1 second intervals, Duo is pingable but FrontView is not reachable.
Firmware re-install (quick reset press) did nothing
Factory reset did nothing (http://home.bott.ca/webserver/?p=306 performed afterwards and files are still visible)
All this after a couple of power hits at home.
Is my Duo dead ? I'm seriously considering junking it and buying a newer one - probably from another manufacturer :(
