2trees
Nov 22, 2013Aspirant
ReadyNAS Duo V1 Capacity max.
I note from the original HDD compatibility listing, that my current unit will accept 1.5TB units. As the model reccomended is no longer available could you please advise current approved drives, great...
Dec 02, 2013Guru - Experienced User
Can you log in via frontview? What status does it give you? (hover over the icons at the bottom left of the home page, also check the logs).
