2trees
Nov 22, 2013Aspirant
ReadyNAS Duo V1 Capacity max.
I note from the original HDD compatibility listing, that my current unit will accept 1.5TB units. As the model reccomended is no longer available could you please advise current approved drives, great...
2trees
Dec 02, 2013Aspirant
Having seen the "dead" comments, decided to replug disc 2. Following your instructions and noticing that the #2 LED was very rapidly indicating the following is Logs after one hour.
VolC raid Level X Resync. 668GB (96%) OF 698GB used
Channel2 ST2000DM 001-1CH 164:1862GB Resync 9% comp.
Hope this means it was a bad install from me and we are out of the woods. If so much appreciate your valued input.Thank you.
